Loud motorcycle noise when accelerating
Old 10-01-2012, 08:33 AM
Elizabeth S's Avatar
Default Loud motorcycle noise when accelerating
Hello,
I need some help please. I have a 2000 Honda Civic Ex 2 door with 125,000 miles on it. I was driving on some big hills over the weekend and my car was having trouble getting up them/accelerating while going up them. It was not a huge deal, but suddenly, now my car is making a loud motorcycle noise when I accelerate. It makes a softer motorcycle noise when it is not moving, but it is very loud when ever I accelerate. It is a manual, so each time I shift it is loud when accelerating. I just got a new timing belt last year, and an oil change less than a month ago. The noise seems to be coming from the front more than the back. When I put the car into neutral the sound disappears. The car does not appear to be shaking or slipping - it is driving just fine, the issue is the loud noise. It this the muffler or the engine? What could this be? Any advice or experience would be greatly appreciated.
Old 10-01-2012, 08:57 AM
boiler1's Avatar
Since you're getting reduced power it sounds like you have a restriction in the exhaust, probably at your catalytic converter. There's a honeycomb looking thing in the cat that can get clogged or damaged. Dont let this go for long.
Old 10-01-2012, 09:38 AM
Ok, I will get it looked at this week. Thank you so much for your assistance!
Old 10-01-2012, 09:46 AM
This could be a hole in an exhaust pipe or even a completely broken pipe. Idle the engine then go and block the tailpipe with a rag. Pressure should build up quietly. If there is no flow from the tailpipe at all, or you hear hissing noises under the car, there is a leak in the exhaust system.
Old 10-02-2012, 12:03 PM
Thanks for the advice guys - I really appreciate it. It was looked at today and there is a huge crack in my catalytic converter - so it needs to be replaced. Thanks again for the helpful advice!
98civicftw
07-15-2010 03:21 AM
islandtuner
05-04-2009 08:54 AM
brian400ex
04-05-2008 05:47 PM
syncro
08-16-2007 01:27 PM
TrAvMaNFTW
02-19-2006 12:19 PM
Quick Reply: Loud motorcycle noise when accelerating
