Loud screeching sound - HondaCivicForum.com
Reply
LinkBack Thread Tools Search this Thread
Old 05-16-2006, 02:40 PM
Default Loud screeching sound
I just had a belt job done on my 94 civic about a two months ago,at that time it had about 155,000 miles.Within the past two weeks since then,everytime I start the engine there is this loud screech coming from the engine bay, it sounds like it could be one of the belts.It lasts for a about 10seconds...sometimes even more and then it goes away. When I'm driving it stops,the screeching sounds appear to come back only when my vehicle gets close to a complete stop or when I turn on the a/c.Could this be something serious?I wanna get it checked out,but I hate to pay an arm and leg for a minor issue, but its getting embarrassing!PLEASE HELP!
Old 05-16-2006, 03:01 PM
Default RE: Loud screeching sound
loose belt. Get under there and find out which one it is before it shreds itself. Press the belt in the middle of the two pullies. There should be ~3/8 to 1/2 of deflection. It's hard to say, because belt tightness is measured with an actual guage. To loose and it slips (screeches) to tight and it puts undue stress on the bearings.
Old 05-16-2006, 08:02 PM
i'd say just tighten both pretty decent to where there not to much slack and see if it stops but don't tighten it to much
Old 05-16-2006, 08:38 PM
What is it with shops leaving belts loose? I had my timing belt changed at a dealer and they did a shoddy job tightening up the other belts.
Old 05-16-2006, 09:38 PM
gwl's Avatar
gwl gwl is offline
If I had a loose belt, I would replace it because its probably already glazed. But in the meantime, you can tighten the belt.
Reply
Thread Thread Starter Forum Replies Last Post
screeching tires sound when driving and stopping continuously at stop signs bubbe2005 Mechanical Problems & Technical Chat 5 02-20-2011 07:59 AM
Loud, loud, loud!!! islandtuner Header, Intake, & Exhaust 27 05-04-2009 09:54 AM
Loud Screeching Noise Mr Mobsta Man Mechanical Problems & Technical Chat 3 12-29-2006 06:10 PM
Loud or loud and obnoxious TrAvMaNFTW Header, Intake, & Exhaust 6 02-19-2006 01:19 PM
screeching noise when turning left nees1212 Mechanical Problems & Technical Chat 4 07-19-2004 09:58 PM
Tags
belt, civic, coming, driving, engine, honda, loud, making, noise, screatch, screeching, sound, start, timing, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
