Need torque specs for rocker arm assembly D15B7 1995 civic
I recently found oil in my spark plug wells then removed valve cover and replaced all gaskets above the rocker arms, not knowing that there were also 4 seals under the rocker arm assembly that also need to be replaced. I bought the 4 seals but cannot find the rocker arm assembly torque specs for this exact engine. Found many suggestions for 6mm, 8mm, and 10mm but this assembly has ONLY 12mm. Does anyone know what the torque ft/lb specs are for 12mm?
called the nearby Honda dealer and they only had specs for 6mm and 8mm...Please Help!
tsmith944
05-06-2011 06:22 PM
