A New A/C or Can It Be Fixed?
Old 04-03-2016, 02:44 PM
Scotty13's Avatar
Default A New A/C or Can It Be Fixed?
I have a 2006 Honda Civic LX and the A/C maybe checking out. When the cars been off for awhile the air works nice and cool. Here's what happens… If I accelerate sometimes after I’ve been driving for awhile, the A/C blows warm air or If I stop to run errnads the A/C will blow warm air after the 2nd or 3rd startup.
Can my mechanic fix whatever is going on or do I need a new A/C?
Thanks,
Scotty13
Old 04-03-2016, 09:53 PM
TiggerDX's Avatar
Depends on the problem. If it low on Freon, that is an easy fix. Could also be the clutch going out. Get it looked at soon, as most issues at this point can be repaired. If you let it go like I did and the compressor seizes, you need to replace most of the system due to contamination.
Old 04-05-2016, 03:29 AM
Scotty13's Avatar
@TiggerDX - Thanks, I recently had freon put in. I'll the mechanic check the clutch.
Old 04-05-2016, 10:09 PM
TiggerDX's Avatar
Did you do it or have a pro do it. Mine was cause by me doing it myself and overfilling the system.
Old 04-06-2016, 01:59 AM
Scotty13's Avatar
I purchased a Genuine Honda 39794-SDA-A05 Power Relay Assembly yesterday. I hope that that will work. Thanks for asking. I'll let you know the outcome when I try it.
n8te81
02-08-2009 05:59 PM
Cherry
05-20-2008 04:46 AM
honda_farmboy
03-13-2008 10:59 AM
timtimmah
02-15-2007 03:55 PM
Black Magician Hiro
01-15-2005 08:47 PM
Quick Reply: A New A/C or Can It Be Fixed?
