New to honda's need help with firing order, Have checked everywhere cant get it right
Old 03-09-2011, 08:43 PM
beat2hell93civic's Avatar
Default New to honda's need help with firing order, Have checked everywhere cant get it right
Ok so new to honda's not new to cars, heres the important stuff:
1993 honda civic lx
I believe the motor is a D15b7
Runs like crap backfiring and wont go fast
Changed plugs
Changed wires
Picture:
PLEASE HELP
btw I know the engine is a hideous green, I just bought it the other day, this poor car has been molested bad
Old 03-10-2011, 04:54 AM
northwoods's Avatar
For a 95 its 1 3 4 2, #1 is furthest from dist cap. Should be the same for yours.
Old 03-10-2011, 09:47 AM
Ed Fisher's Avatar
Default proper spark plug orientation to the distributor
As the previous poster said the order is 1, 3, 4, 2. Just to offer a little more clarification:
The #1 plug is furthest from the distributor, #2 next closest, #3 next closest, #4 closest. If you are looking at the distributor as mounted on the car, with the flat portion at the top, the #1 position is at 7 o'clock, the #3 position will be at 10 o'clock, the #4 position at 2 o'clock, the #2 position at 5 o'clock. These are relative positions that will get your firing order correct, however, correct timing of the car should be done with a manual, and a light.
Good luck,
Ed Fisher
Dallas, Tx
Default Update
Fixed firing order, now it wont start, is it possible the distributor was installed improperly? it also backfires in an attempt to start. Probably going to have to break down and take it to a mechanic, can't say this is my proudest moment any other things I could check?
Old 03-10-2011, 10:05 AM
Ed Fisher's Avatar
should look like the attached picture right?
Attached Thumbnails New to honda's need help with firing order, Have checked everywhere cant get it right-honda-distributor-ii.jpg
Old 03-10-2011, 10:11 AM
Ed Fisher's Avatar
there really isn't a way to get the distributor 180º out since the lugs and grooves are offset and will only accept one orientation. See attached.
Attached Thumbnails New to honda's need help with firing order, Have checked everywhere cant get it right-distributor-lugs.jpg
Old 03-10-2011, 10:37 AM
Number one piston is on driver side, #4 is close by distributor
Old 03-10-2011, 11:12 AM
Does my distributor look like it is properly installed? Based on the diagram I was looking at it looked like it was off
Old 03-10-2011, 11:51 AM
yes the distributor is fine, there is only one was it installs.
Old 03-10-2011, 11:58 AM
Talked to a Mechanic said it was the timing belt, guess i get to scrap it... what a ****ing waste.
Quick Reply: New to honda's need help with firing order, Have checked everywhere cant get it right
