No crank no start smoke from dash?? Please help
Old 05-01-2015, 09:23 PM
Dwillis's Avatar
Default No crank no start smoke from dash?? Please help
Recently got a 2001 civic from a friend. It had been sitting in her yard for about two years (started occasionally) before I got it. I put a brand new battery in and started driving. It's been about a week now and the other day the tail lights burned a fuse. I thought I may have done something wrong when installing a new radio but I only replaced the fuse and the lights worked fine, I drove home. The next day I was cleaning her up with radio on and smoke started coming out from under dash. Lights, radio, windows, etc all still work. Relay clicks when key turns to on position but nothing more afterwards. Starter makes no sound at all. I am completely lost. Anything will help and be greatly appreciated. Thanks, Darrick
Old 05-01-2015, 09:30 PM
Dwillis's Avatar
200k miles
Old 05-02-2015, 07:47 AM
Is there any other aftermarket wiring such as an alarm system?
In the old models the tail light circuit went to the radio to light up the dial on a stock radio (this wire is generally not used by aftermarket radios, so it needs to be taped up to prevent shorts), I don't know if that is still the case with a 2001.
Old 05-02-2015, 10:19 AM
Dwillis's Avatar
I had an alarm that was disconnected. I tried to completely remove the alarm at the same time of all this. I plugged two black wires back into alarm box and fired right up. Still can't figure out where the smoke was coming from. Thanks for responding
zerojett
10-18-2011 03:01 PM
Da64u
12
12-29-2010 08:37 PM
WellFedHobo
09-29-2009 07:43 PM
bmelloh
05-16-2009 08:01 PM
snosurfa7
05-05-2006 08:21 AM
Quick Reply: No crank no start smoke from dash?? Please help
