no fire from dizzy to plugs
need help please i have a 92 vx hatch with a d16z6 and a p28 witch came stock. i checked the entire harness and the timeing and bought brand new dizzy and plug wires and plugs. i have fire to the dizzy just none to the plus i checked the diy for cel codes and it stayed on and threw no codes. motor also turns over.PLEASE HELP ME HONDA GODS lol.
Testing from the coil output spring to a grounded test wire, you should get bright blue sparks that can jump more than 1/2 inch. Weak yellow sparks aren't going to make it to the plugs, that usually means the coil is bad.
If no sparks at all, check that the black-yellow wire to the distributor has battery voltage while cranking.
