no heat at idle in 2003 civic
Did you check the level in the radiator itself? It can be "normal" in the white plastic tank but actually low in the radiator and engine where it matters.
If it's not that, you may have a partly blocked heater core, flushing it out could help.
Thanks, I will check the radiator water level first thing tomorrow.. checked the radiator this am, even though the reservoir was full the radiator was not full. added coolant and heater ok now......Thanks, I learned something new today....
Keep an eye on it. The radiator cap controls the flow in and out of the reservoir, try a new one if it happens again. Ordinarily the radiator should be full to the top when you open the cap (only with the engine COLD of course).
sylver8248
08-27-2008 05:23 PM
