97 Honda Cr-V no spark
Old 02-07-2020, 12:33 PM
ConfusedGuy's Avatar
Default 97 Honda Cr-V no spark
Okay I know it isn't a civic but the motor and electrical is nearly identical. I am looking into a problem a friend is having. Without diagnosing anything he just started throwing parts at it. The spark plugs, plug wires, coil, and ICM are all new. Today I tested the ignition switch. All checks out good. Then I checked the main relay. It also function as it should. I am currently charging the dead battery so I can do voltage tests. I just want to get a jump on what I will be looking for when I have power. Which wire going to the Distributor is 12v supplied by the ECM? Is there a wire to test pulse at the Distributor? Does anyone have a pin out list for the ECM? Any help is greatly appreciated!
ukrkoz
14
03-01-2022 07:11 PM
19civic95
08-13-2012 02:56 PM
RonJ
Routine Maintenance DIYs
01-10-2010 01:23 PM
atommizer
06-21-2009 09:26 AM
Rmpge15
05-02-2008 06:14 AM
Quick Reply: 97 Honda Cr-V no spark
