No pressure in any cylinder
Old 02-04-2016, 03:55 AM
aroundtown's Avatar
Unhappy No pressure in any cylinder
Hi,
I have a 2002 LX with 240000 miles. The other morning, without warning, it didn't start when I was getting ready for work. It would crank but not turn over and start. No diagnostic lights on, has gas and oil.
I've checked the battery, checked for spark, checked that the fuel pump is running.
When I put a compression tester on each cylinder, I removed the relay to stop the fuel pump. Each cylinder had 0 or 5lbs pressure max. It was suggested to me that this might mean the timing belt but we looked down into the oil fill port and could see the rocker arms moving when it was cranked.
the engine has oil all down the front of it and on the side opposite the timing belt. The dipstick still shows oil is present in the engine.
Any suggestions?
Old 02-04-2016, 10:00 PM
Jcrew's Avatar
Default d17a1?
is your head gasket bad? is there oil in the coolant? vise versa? did it blow smoke?
lunger
07-10-2011 02:50 PM
phan10m
07-07-2007 04:27 PM
sway2003
12-27-2006 07:33 PM
jax00civic
07-22-2006 04:51 PM
Quick Reply: No pressure in any cylinder
