not starting
not starting
i have a 92 civic lx manual and i replace the fuel pump and it ran for a day then wouldn't start so i replaced the relay and it still wont start. And the fuel pump isnt priming. Any help would be nice
If you're sure the main relay is good, it's probably the ECU. The ECU turns the fuel pump on and off through the main relay.
When you turn the key on but don't crank, the check engine light should come on for 2 seconds and then go out. If it stays on, that's a sign that either the main relay or ECU is not working. In case the light stays on, you can try leaving the key on for several minutes to see if it ever goes out. If the light goes out eventually and then you can start, it's almost certainly a bad ECU.
Also check the ECU ground wires (on the thermostat housing near the starter under the hood.)
totenkopf
05-31-2007 03:36 PM
Impreza WRX
05-07-2006 02:01 PM
