Are our 2001 civics known for oil consumption?
Old 04-24-2014, 02:31 PM
pippo's Avatar
Default Are our 2001 civics known for oil consumption?
People,
have a 2001 civic EX, AT, and only has about 110,000 miles on it. It has slowly, steadily ben increasing its motor oil consumption. meaning, its been happening for a while (2 years or so). Now, it consumes say, a quart every 500-600 miles. Geez- the revered civic burning oil so soon. Is this normal for our cars, people? (I have taken very good care of the engine ever since new).
Old 04-24-2014, 02:36 PM
itburnswhenIP's Avatar
no these cars are not known for burning oil they are known for faulty auto transmissions.
Old 04-25-2014, 03:41 AM
pippo's Avatar
Thnaks, it. Yes, I learned right here on this forum about the junk AT's- mine broke 2X. But was wondering why Im burning oil. Thing is, no blue smoke upon start up. Maybe not that bad yet. We'll see.
Old 04-25-2014, 05:22 AM
Check or replace the PCV valve. Have someone follow you in another car and watch for smoke. Smoke that gets worse when you floor the gas means that the rings are worn.
Old 04-25-2014, 12:43 PM
pippo's Avatar
good tip, MK. Will plan on doing that asap......come to think of it, never changed that pcv valve. Time to do it......
Old 04-25-2014, 12:50 PM
there are two valves the pcv on the valve cover is metal so no need ro replace just remove and clean it with carb cleaner.you mite as well clean your EGR and IACV while your at it. this is a good 7th gen diy page DIY: forgotten tune-up mods - Honda Civic Forum
Old 04-26-2014, 03:54 AM
pippo's Avatar
Nice link, it. Now i got a weekend project! Meanwhile, I did do that test- accelerated while watched that tailpipe and no visible bluish smoke, which is good. Must be low level burning. Maybe seepage from the valve cover, which is oozing, but all that oil cant be from that as it doesnt even drip onto the floor/driveway.
Old 04-26-2014, 07:38 AM
be careful when removing the iacv screws there in tight and they strip easily. also im guessing the leak is coming from your rear cam seal not the valve cover. when it leaks it seeps around the valve cover its a easy fix. the cap is 8 dollars at the dealer i did mine last week actually here is a diy. you mite as well replace the cap while the egr is off. note your going to need a small Swivel socket adapter to get the egr off
Old 04-27-2014, 04:36 AM
pippo's Avatar
I think we're on the right track, IT!! Youre so helpful- big thanks!! Yes, ther is much goo in that area, but I should first wash of with engine cleaner, then drive for a week, inspect for fresh oozing to confirm.......Thanks.
Old 04-27-2014, 04:41 AM
there's no need the cam seal is definitely leaking they always leak this is an issue stemming back years and different makes and models replace the cap then clean off the engine.
Quick Reply: Are our 2001 civics known for oil consumption?
