*HELP NEEDED* Honda logo
Old Aug 27, 2018 | 02:46 AM
Kyle_7669's Avatar
Exclamation *HELP NEEDED* Honda logo
hi guys,
i have a 2000 honda logo 1.3 with the fault code 61-01 battery voltage malfunction. this code is in the abs module and is causing the abs light to be illuminated. i have tested the battery and alternator.
these were the test results;
cranking volts: 10.93
alternator idle volts: 14.36
alternator load volts: 14.2
what can be causing this fault to be present? ive tried erasing the code but it wont erase, ive also fully charged the battery incase it was a little low, and i read online that the abs module plug could have been dirty causing the problem? so i have disconnected the plug and cleaned with electrical contact cleaner and compressed air.
Im starting to run out of ideas as to what can be causing this fault code. Any help would be much appreciated!
Thanks in advanced
Kyle
Syn.
Jan 9, 2014 05:14 AM
rpetters
Dec 11, 2013 11:16 AM
milhouse
Sep 26, 2013 05:31 PM
saiguanas
Jun 19, 2008 08:07 PM
civicinNH
May 26, 2008 05:14 PM
