P1456 code and reset
Old 12-18-2006, 02:09 PM
dasso10's Avatar
Default P1456 code and reset
I got the 1456 code for fuel tank pressure. I tightened the gas cap and will be driving the car a lot today.
Will the computer turn off the check engine light if this was the problem, or do I have to reset it myself.
If I have to reset it myself, should I drive the car today to build up pressure before resetting??
Old 12-18-2006, 03:11 PM
cderalow's Avatar
Default RE: P1456 code and reset
will eventually turn the light off after about 4-5 drive cycles, or get it cleared at autozone etc
Old 12-18-2006, 03:55 PM
mxs's Avatar
mxs
mxs is offline
before you start the car, turn the key to the accessory position and let it sit for 10-15 seconds.
Old 12-18-2006, 05:18 PM
dasso10's Avatar
ORIGINAL: mxs
When I turn the key to the accessory position the light comes on after about 1 second and did not reset. After driving the car a lot today Im thinking that I'll go buy a new gas cap to see if that works. Thanks for the quick reply.
Old 12-18-2006, 07:43 PM
dasso10's Avatar
Ok got the light reset by pulling #13 fuse and have drove a couple of times without the light coming back on.
Thanks everyone for all the help....hope I won't need to ask any more questions.
98civex
05-14-2014 07:39 AM
mrtimepa
06-20-2013 08:33 AM
devolic
07-14-2010 09:07 PM
aeromang
04-15-2009 12:48 PM
lumkichi
11-25-2005 05:42 PM
Quick Reply: P1456 code and reset
