please help again. car wont start
Old 12-10-2008, 07:59 AM
mtchu736's Avatar
Angry please help again. car wont start
yea the title says it all. i drove it all last night fine no problems at all. next morning going to work would not start just keeps cranking, i hear the fuel pump. lights and everything work. its a 95 civic d16z6 it has never done this before help!!!!
Old 12-10-2008, 08:05 AM
Please remind everyone about what you have already done and checked up to this point.
Old 12-10-2008, 08:12 AM
mtchu736's Avatar
i fixed a vac leak and it drove fine all last night. but this morning it would not start THE END. i did nothing i looked at all the spark plug wires they look fine. battery seems good. idk im confused
Old 12-10-2008, 08:14 AM
How did you fix the vacuum leak? Where exactly was the leak? Have you checked for spark at the plugs?
Old 12-10-2008, 08:15 AM
mtchu736's Avatar
new gasket fixed leak. there is a spark at the plugs.
Old 12-10-2008, 08:21 AM
More information will probably quicken a diagnosis.
Is the spark bright blue or weak orange? Did you check at all four plugs? How did you check for spark?
What specific gasket did you replace? What did you remove to replace the gasket? For example, if you removed the throttle body and/or intake manifold, then double check that the MAP sensor and fuel injectors are tightly reconnected.
Is the CEL ON?
bmelloh
05-16-2009 08:01 PM
tankz400
02-14-2007 03:41 PM
gpacheco101
01-23-2007 05:29 PM
gpacheco101
01-18-2007 07:15 PM
92civicb16a
09-05-2005 09:19 PM
Quick Reply: please help again. car wont start
