Please Help, electrical problems?
Old 08-01-2012, 07:55 PM
Alison Green's Avatar
Exclamation Please Help, electrical problems?
I was driving my 96' honda civic the other day in a bad storm, after awhile the check engine light came on, fading and then getting brighter, kind of in a blinking manner. The headlights were blinking the same way, and the speedometer stopped working, it started going crazy up and down. The car also is shaky and doesn't feel right. I checked the codes a few minutes ago and it says:
vehicle speed sensor,
electrical load detector (ELD) voltage high
Oxygen sensor heater bank 1 sensor 1
Oxygen sensor heater circuit bank 1 sensor 2
I'm pretty sure all these things couldn't have happened at once, could it just be electrical? please help. thankyou
Old 08-02-2012, 06:28 AM
This suggests the classic "fuse 15 problem". Search for it. The symptoms include:
* 1996, 1997 model
* Speedometer doesn't work (no power to speed sensor)
* Heater codes for both O2 sensors (sensors are OK, but no power to them from the fuse)
* Low / pulsating voltage from the alternator (alternator OK, but no power to it from the fuse)
Old 08-05-2012, 09:26 AM
I tried doing everything I found online but no luck, still all the same problems
Old 08-05-2012, 06:16 PM
conceptualpolymer's Avatar
You could have a bad battery or an alternator that is overcharging the battery, or both. First have the battery load-tested and if it's good, have the alternator tested.
Old 08-05-2012, 07:41 PM
What did you try doing?
Fuse 15 not blown?
Wires behind the engine not frayed? (you must get under the car and look from underneath)
Battery voltage reaching the black-yellow wire at the alternator with the key on?
96civic96
05-16-2011 11:47 AM
Oblivionlord
07-18-2010 09:42 PM
jswindow
04-11-2007 04:28 PM
Dr Talon
12-08-2006 12:30 PM
goddspring
10-14-2006 01:37 PM
Quick Reply: Please Help, electrical problems?
