power window stuck
power window stuck
yet another problem with my piece of ****. its one thing after another. well its always been off track a little bit but now it off of the track completely i see where the glass is supposed to be, in between these rails or something it is behind it and when i try to go up it just clicks no motor, i know the motor is fine though. i cant even pull it up with my hands it gets stuck half way what am i going to do
Pull off the door panel and place the window back into its side channels. Before reinstalling the door panel, spray some silicone lubricant into the top of each side rubber channel where the window edges slide, and let the lubricant drain down the channel by gravity. Next, connect the window switch, and roll the window up and down multiple times to ensure that the window now moves freely. Install the door panel, and you should be good to go.
hey ron i have question on the right side i took the bolt off of the regulator to get the window out. but how do you get the bolt back on do i need a bushing in there because the bolt goes right through or am i using the wrong bolt?!
