Pulled the CEL codes - Where do I start now?
Old 03-12-2016, 06:09 AM
RunNRhino's Avatar
Default Pulled the CEL codes - Where do I start now?
I have a 99 civic EX, one day it started to misfire and spuder while accelerating from a dead start; seemed to run ok once in the 2700-3000 rpm range. The next day the check engine light came on and it's running worse. I pulled the codes and got the following:
P0705 Trans - Trans Range Sensor A Circuit malfunction (2-posi)
P0706 Trans - Trans Range Sensor A Circuit Performance (2-posi)
P0301 - Eng - Cyl 1 Misfire detected CURRENT
P0302 - Eng - Cyl 2 Misfire detected CURRENT
P0304 - Eng - Cyl 4 Misfire detected CURRENT
P1399 Eng - MIsfire Detected Current
P0301 - MOD $oE Cyl 1 Misfire Detected CONFIRMED
P0302 - MOD $oE Cyl 1 Misfire Detected CONFIRMED
P0304 - MOD $oE Cyl 1 Misfire Detected CONFIRMED
P0300 - Random Multiple Misfire Detected CONFIRMED
P1399 MOD $OE Misfire detected PENDING
I have not done a tune up in a while and I have an exhaust leak that may CAT or above it. Any suggestions on what I should do to identify the cause or where I should start?
Cullenator
11-29-2013 05:09 PM
civicpryde
03-08-2008 03:37 PM
xeno
10-19-2005 11:37 AM
stevenmgrr
09-30-2005 09:01 PM
stevenmgrr
09-30-2005 08:21 PM
Quick Reply: Pulled the CEL codes - Where do I start now?
