Rear door will not open from outside
Old 11-24-2009, 10:38 AM
Karado58's Avatar
Question Rear door will not open from outside
1998 Honda Civic Sedan
My passenger rear door will not open from the outside, only inside handle opens it. When I use the outside handle, it feels like it is not attached to any linkage, but has normal tension just like if it was locked.
Maybe coincidence, but this happened after i installed an alarm.
Thanks for any help.
Old 11-24-2009, 12:24 PM
take the door panel off and look inside at it, the linkage may just need adj.
Old 11-24-2009, 01:04 PM
supersize's Avatar
Sir Banned-a-lot
i was going to say child proofing but thats the opposite way around, like chb said, your best bet would be to take off the pannel and inspect, pull it from the outside and see waht it does and then pull it from the inside. it could just be a spring or something small like that
Old 11-24-2009, 03:49 PM
Karado58's Avatar
Thank you both very much, I'll do that.
mrossi22
02-04-2015 10:28 AM
relentlesstech
05-30-2012 05:40 AM
bigmikew1
11-09-2008 05:58 PM
Lambo Civic
06-01-2008 03:11 PM
rawrob71
01-31-2006 02:12 PM
Quick Reply: Rear door will not open from outside
