right rear door won't open from inside or outside
Old 09-24-2007, 05:39 AM
Lambo Civic's Avatar
Default right rear door won't open from inside or outside
The guy I bought my civic from told me he flipped the switch, which I think is supposed to be a child-lock or something, to the lock position on the inside of the door and he said after that the door wouldn't open even with the door unlocked. It won't open from the inside or the outside. Is there some way I can fix this w/o having to go to the dealer/mechanic? Thanks.
Old 09-24-2007, 06:02 AM
Default RE: right rear door won't open from inside or outside
well dang that sucks.... but i think youll be able to fix it.... first pop out the bottom of the rear seat and try to take off the door panel. now im not positive where all the screws are at on the door but id asume its like my coupes front doors and only a few screws with mostly clips on the door panel.... would be best to remove the door panel on the OPENING DOOR that way ya know how exactly it comes off.... then check out the rods inside the door and everything! get your hand in thier and start pullen and pushen on rods up and down and hopefully its just a rod came off or the lock rod is just stuck to lock.... like if its power locks maybe the lock actuator wont work so its stuck to lock...
and if ya get the door open turn the child switch off and test the door latch again BUT without closing the door... use like a large screw driver or something to move the latch closed and try to open it with the handles again....
Old 09-26-2007, 10:20 AM
ORIGINAL: addiction2bass
I've taken off door panels before off my last two cars, but I've never removed a rear seat (or a front seat for that matter). What do I need to look for to do that? Do I have to get underneath the car and take out some bolts? I have no clue. Thanks for your first response.
Old 09-26-2007, 04:30 PM
foress_89's Avatar
THe back seats are molded in the car, you can remove them like the front seats. Remove the cushions, you'll have more space to work on the door.
Old 06-01-2008, 03:11 PM
I have the same problem with my car on the other side. Did you ever get this fixed. If so, how?
Rick
mrossi22
02-04-2015 10:28 AM
Zeroalex
12-25-2013 10:49 AM
cmpr611
07-21-2010 12:10 PM
Karado58
11-24-2009 03:49 PM
Forty04
07-11-2005 08:24 AM
Quick Reply: right rear door won't open from inside or outside
