Squeaky clutch
Old 10-12-2005, 07:12 PM
Spartan21's Avatar
Default Squeaky clutch
Hey all....
My clutch squeaks when I hit it. Could this mean anything? Its been doing it for a while.
Old 10-13-2005, 02:58 PM
Default RE: Squeaky clutch
It could posably be the throw out bearing other wise the clutch parts could be loose like the rivots. but maby someone else can help out better but good luck
Old 10-13-2005, 03:15 PM
mill$civic's Avatar
i no if my car is off and its all quiet around, when i push down my clutch you can hear it squeak a little bit...i think thats just natural tho, unless it sounds really loud or somthing
Old 10-13-2005, 03:20 PM
Remmy's Avatar
Spray Super Lube the pedal assembly, I had squeakyness with my old 240 till I did it.
Old 10-14-2005, 06:50 PM
When you open your hood, the left of the cat on the trans, you should see a rubber cover,(thinking you have a 96 and up) pull the rubber cover back and spray some WD40 or some other type of lube and that shoule do it.
inthezoneac
10-16-2008 08:30 PM
mixwhit
06-23-2008 08:21 AM
WhiteRabbit1021
07-15-2007 09:33 PM
dooka4u4
08-04-2006 08:05 AM
dooka4u4
07-18-2006 02:51 PM
Quick Reply: Squeaky clutch
