Squealing serpentine belt
Old 02-03-2016, 09:09 AM
706jim's Avatar
Default Squealing serpentine belt
Our 2003 Civic still runs, but occasionally will make a shrieking noise that I would assume is coming from the serpentine belt. This will go on for a minute or so usually when the engine is cold and then the noise will stop.
Mileage is around 190,000km.
Any idea of what component might be causing this noise or any other suggestions from others who might have heard something similar?
Old 02-05-2016, 08:21 PM
itburnswhenIP's Avatar
you need to tighten the belt i suggests you buy a manual if you plan on doing it yourself or pay someone to do it. either way it needs to be tightened. also depending on the mileage of the car it mite actually need to be replaced entirely.
Old 02-06-2016, 09:41 AM
706jim's Avatar
Thanks for the reply. (Sorry about your urology problems......)
The car has 195000km and has the original belts. You are probably right in suggesting replacement of both.
Old 02-10-2016, 01:56 PM
jonsey1886's Avatar
Replace them ALL:
Timing
Serpentine
Drivebelt (runs A/C, Power Steering, etc)
Old 02-11-2016, 06:02 AM
706jim's Avatar
Or maybe we'll just replace the car. Lots of rust up here in the north.
Old 03-03-2016, 09:48 AM
fblevins1's Avatar
I did not research your car, but it was my understanding that serpentine belts had auto tensioners. If it does, it could simply be that it is worn and needs to be replaced. If it does not have an auto tensioner then I believe the above advice should take care of the problem. Replace the belt and tighten to specs.
Northender_85
08-28-2010 09:16 AM
pippo
01-26-2010 02:40 PM
trustdestruction
08-30-2009 05:18 AM
Flyboy
03-29-2009 05:17 AM
Graygod
05-23-2008 07:49 PM
Quick Reply: Squealing serpentine belt
