Still have oil leak after valve cover gasket
people,
replaced bad valve cover gasket, and installed a new camshaft end cap. Looks nice/no leakage up there anymore. But I still have drops collecting under oil pan and dripping on driveway. So I asume gotta be pan gasket. Do you agree and is pan gasket typically at fault on these cars? (2001 civic AT)
thanks
thanks
I concur - the cam plug is the main culprit on these vehicles. Oil pan and valve cover are usually fine. Did you replace the ring gaskets at the top of the valve sleeves as well? These are often overlooked.
Check the cam plug first. Take it out again, thoroughly clean everything, get some ATV gasket, apply a thin coat and reinstall. Clean everything to get any residual oil off and check
martinc98
12-06-2013 07:30 AM
Execut1ve
02-06-2012 07:29 AM
Speed JUnkyz
03-15-2010 03:34 PM
inthezoneac
02-26-2010 06:24 PM
mill$civic
10-31-2005 06:25 PM
