taillight not aligned to the trunk
Hello, I got a 2002 civic LX and found that my tailights are not align with the lights onmy trunk door (higher)and there's a big gap between the outer taillight and the bumper. (this happen after bumper was replaced after a hit).
So any suggestion onwhat I can do to fix this problem?Could this be done by a regular personor should I bring it in to the body shop.
Try adjusting the trunkfrom the trunk arm (if thats the right name for it) by adjusting the position. No change....
The problem is similar to the one seen in the image, plus a gap between the outer tail light and bumper as mentioned earlier in the post.
Any help will be good. Thanks in advance.
[IMG]local://upfiles/29791/6881B2DC21A446E080C6E3C6600773E8.jpg[/IMG]
RE: taillight not aligned to the trunk
Something besides the bumper got bent in the hit. If insurance (especially the other guy's insurance) paid for the repair, you need to go back to them and demand further repairs.
ORIGINAL: magnodrome
some creative answers.... does anyone have similar type of problem that they are facing.
mk378 - accessed to insurance is not possible. Thehit incurred when my aunt had the car a year or 2 yearsago. So any fixing with be out of my own pocket.
If I was to leave it as is, will it lead to water leaking to areas of the car that shouldnt be.
Thanks again
Thanks again
well first thing i would try is loosening the taillights mounting bolts and see if you can move the tailights around any... if you could move one tailight UP and the other DOWN or vis versa you could posibly line them up ok.
look at 2 things, one the trunk lid around the top corners... if its level with the side quarters then id say its the taillights just being aftermarket, typical fitment issues....
then i think your only choise if ya want them lined up is taking out the taillights and using a small dremel to grind the holes alittle larger in the way you want the taillights to move., might just have to put alittle silicone around the holes before reinstaling the taillights just to prevent any leaking from the larger holes.
but if the trunk lid and side quarters dont line up then you should adjust the latch or catch rod on the trunk lid to make them line up properly.
you should be able to do it yourself.
i have an o3 and i have problems with the lights not fitting right but its the aftermarket lights not the trunk or nething if you want i have oem(stock) taillights if your interested check my thread.
altitude_19
13
10-04-2011 08:49 PM
addiction2bass
06-08-2007 06:02 PM
burnoutNshootnos
12-25-2004 10:07 PM
burnoutNshootnos
12-22-2004 10:30 PM
