what size nut?
Old 09-28-2006, 07:23 PM
DreamTeam87's Avatar
Default what size nut?
does ne1 know what size nut goes on the (I think its called throttle braket... what you connect the throttle cable to) its a 1994 honda civc ex sohc cause mine is almost stripped out and i dont wanna take it out unless i know for a fact i got the right size nut just in case its gets so stripped that i cant replace it.....
Old 09-29-2006, 06:56 AM
natecivic92's Avatar
Default RE: what size nut?
If it is 6 points make sure you use a 6 point socket.or if it is a Place you cannot get a socket use a line wrench or in worse case vise grips.
Arthall111
06-02-2015 09:03 AM
tlkolrod
07-16-2010 06:53 PM
antle89
06-20-2010 05:18 PM
snosurfa7
05-21-2007 07:24 PM
mentaldis0rder
04-05-2006 08:09 AM
Quick Reply: what size nut?
