Timing belt Change, car wont start
Hi all I have a 2001 Honda Civic EX. I recently changed the timing belt. Upon starting the car, it ran good for about 2 seconds, then sputtered and died. Now it will not start at all. Any idea what could have caused this? I was pretty certain that I had it in time when I replaced the belt (until the car died lol). Is there anything that could have happened or something I forgot to connect that could cause this? I am sure I got the cam sensor and crank sensor connected when finishing the job. Any help is appreciated.
Thanks for the advice. I will check the cam timing tomorrow. I am sure it was very tight when I sealed it up, but I will check to make sure. I am getting no ECU codes. Is there anything that could have happened that would cause my fuel to get shut off?
I think I might have actually been off a tooth or it jumped. Is there anything special I need to do with the tensioner to release the tension besides loosen the bolt and spring? When I put on a new one, I know it was important to know pull the grenade pin until it was done, but now I have obviously already pulled it.
THanks for the replies. I am thinking I might have screwed myself. It didn't seem badly out of time, maybe two teeth at the most. But after popping the valve cover off, I noticed that every other intake valve had about 1/4" of play when it was at TDC. I don't have a compression tester right now, but I am thinking that I crashed the valves.
patm95
08-17-2013 11:05 AM
dave_57204
02-05-2008 08:14 AM
dave_57204
01-27-2008 10:16 AM
