WD-40 Safe for Ignition Switch? - HondaCivicForum.com
Reply
Old 07-18-2007, 12:54 PM
Default WD-40 Safe for Ignition Switch?
Recently, my ignition has made it hard to turn the key from the Accessory postion to lock (where you have to push it in slightly). Would WD-40 be safe to spray a little into the key slot, and put some on the key itself? If not, what do you recomment I do?
PS, I know in the manual it says it's possible that if your wheels are turned one direction or the other, it can make it hard to turn the key, but this issue happens in all wheel positions.
Old 07-18-2007, 01:12 PM
ej6buddy's Avatar
Default RE: WD-40 Safe for Ignition Switch?
i'm not sure, i've never heard of that problem, but i guess you could slide a little grease on your key and try to wiggle it around in the slot. a little wd40 shouldn't hurt it, just not too much or you'll probably short something out if it leaks out.
Old 07-18-2007, 01:15 PM
Lol that's what I was thinking, I'm just going to spray it on my key and give it a try. Thanks for the quick reply!
Old 07-18-2007, 01:21 PM
I think just putting it on the key won't do much as it needs to go deeper into the mechanism than that. Most mechanical things survive being doused with WD-40 but you may be the one to find an exception.
Reply
Thread Thread Starter Forum Replies Last Post
DIY Combination Switch Fix (Headlight Switch) danomatic93 Routine Maintenance DIYs 4 01-15-2012 07:16 AM
94 civic ignition switch Q dartax Mechanical Problems & Technical Chat 2 05-29-2010 08:22 PM
Ignition Switch bceja10 Mechanical Problems & Technical Chat 4 10-04-2006 02:14 AM
key can't be removed from ignition switch b3651 New Member Introductions 2 09-24-2005 09:46 PM
ignition switch or not? tech support needed aredecomm Mechanical Problems & Technical Chat 4 06-06-2005 03:11 PM
Tags
40, civic, civix, honda, ignation, ignition, key, put, safe, safest, short, spray, switch, wd, wd40, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
