Welding cracked exhaust manifold
Quick question. I have a 99 DX with the obligatory cracked manifold. The dealer has already turned me down for warranty work, so I am left with 2 options. Try and weld the crack shut or buy a new/used part. Being that I have extremely limited funds I would like to try and weld the manifold.
I would like to weld while the manifold is still connected to the engine, to prevent warping. Is there anything I need to do to protect the computer while I weld?
Thanks for any/all comments.
RE: Welding cracked exhaust manifold
i have seen welded one last a while but if u dont have funds i would say cut off and use stock flange ang make ur own 4-1if u have some good welds to lay down i did it a while ago to mine looked sweet and had like 10$ in pipe
i have the same problem, at first i took it off & welded it then put it on - the weld cracked
welded it agian on the car, its hard to get under the bottom
& it still leaks[:@]
[sm=signs003.gif]
[sm=signs003.gif]
briceman124
01-19-2012 06:36 AM
kadir
01-15-2010 05:33 PM
2spooky
03-22-2006 09:25 AM
