Where is my coolant temp sensor
Old 05-11-2007, 12:47 AM
NewClimber's Avatar
Default Where is my coolant temp sensor
OK, I have been reading most of the night, but just can't seem to find my answer. My temp gauge, jumps from hot to cold to normal(about 1/3way up). In looking for the temp sensor, the Previous owner did a very poor job of wiring.
I see on the trany side of the block I have what looks like 3 sensors. Ones has a single wire just under the Dizzy. There is one 2 wire connector next to that towards the front of the motor, and then one 2 wire connector to the tranny. I was assuming the single wire was the temp sensor, but it looks alittle difficult to get to with out taking the dizzy off. I was assuming the 2 wire connectors goes to the fan relay, and I was not sure what the 2 wire connect on the trany was for. But after reading tonight, the single wire could be the oil pressure sensor. I had thought I tested this 1 wire sensor, by putting it to ground and the temp gauge did spike all the way to hot.
Am I on the right track, is the single wire the temp sensor, and the 2 wire connector the fan relay??
Oh, it is a 1988 civic DX...with a D15B motor. I was told it was a swap...I will try and take some pictures today if that would help..
Old 05-11-2007, 03:17 AM
Default RE: Where is my coolant temp sensor
eehhh, I dont knowfor your specific model, but its usually found on the T-stat
Old 05-11-2007, 05:52 AM
mlobitz's Avatar
Member
The ECT switch is on the Tstat cover. The sending unit and sensor should be in that general area as well.
Old 05-11-2007, 04:41 PM
NewClimber's Avatar
Sorry for the novic questions but what does ECT switch stand for?? I am assuming you are refering to the fan switch but what does ECT mean??
I quess one why to narrow it down....will the temp sensor have one wire or two wires???? I figured the fan switch will have 2 wires. Also, where would the oil pressure sensor be located??? On that same side of the block??
Old 05-11-2007, 08:43 PM
brokenarmboy19's Avatar
http://spoonhonda.com/index_mozilla.htm
there you go free helms manuals(the service manual has EVERYTHING)
Old 05-14-2007, 05:19 AM
mlobitz's Avatar
Member
Engine Coolant Temperature
slowcivic
07-30-2010 07:45 AM
asechrist
12-20-2008 10:59 PM
fglaustin
03-27-2008 08:29 PM
packman5280
02-12-2008 07:46 PM
n8te81
16
07-06-2007 06:16 PM
Quick Reply: Where is my coolant temp sensor
