Why is it always the Rad?!
Hello forum users, so I have replaced 2 rads in two vehicles I have owned this year and I walk out this morning to notice a very small leak in my new (to me) SI's rad Now my only fear is I cant see where the leak is coming from and last time I experienced this was on my 96 Acura TL 3.2L and it turned out the head was warped and I had to sell it for low low... so my only question is, could there be a problem with the block or head when my compression is 175-180 ? thanks.
No overheating just worried because I cannot locate the leak and I only lost about 2 table spoons worth of coolant, when my Acura had a head problem it did a similar thing when it got warm it would over pressurize and push coolant from the cap, until it eventually cracked the whole rad and started steaming from the tailpipe. I am probably just worrying but I've had bad experience this year with cooling systems and Honda's.
Check the head gasket by taking the radiator cap off (cold)-- it should be completely full. Then start the engine (cold) with the cap off and rev it. If no bubbles come out of the radiator the head gasket should be OK.
trebor_2005
05-19-2006 01:40 AM
95CIVICUS
12-05-2005 07:34 PM
