problems with ecm or crank shaft positon sensor or both
Old 04-16-2012, 06:32 PM
packman's Avatar
Default problems with ecm or crank shaft positon sensor or both
I have a 2001 Honda civic EX, 5 speed. Mechanic told me I was getting false codes from ecm, one of them being the crankshaft position sensor was bad or out of range. Honda technician said ecm was bad or going bad. I sent the ecm to AES to repair. I got it back and installed the ecm and now the car acts like it has a rev limiter at 3000 rpm. A mechanic friend pulled a code off of it and it was a p0336 which was a crank shaft position sensor out of range. I went ahead and replaced crank shaft position sensor and nothing changed. Does anyone have any ideas on what else to check? I have contacted AES but I have not heard anything from them.
Thanks
Old 04-17-2012, 05:55 AM
There is probably a Crankshaft position sensor in the distributor that is commonly overlooked.
Old 12-05-2014, 07:23 PM
SmileyJoe's Avatar
Default I'm having same problem, did you figure it out?
Changed the crankshaft sensor 3 times and it's still reading that code. I even changed the computer and paid dealership to reset keys to the computer and it's still not right. It cranks over about 6-8 times before starting and then it starts sputtering when driving it.
2005 Honda Civic LX
Automatic
4 door
Old 12-07-2014, 05:34 AM
Check that the timing belt is in time. I think that code results when the crank and cam sensors don't agree. Timing belt out of time will also result in terrible performance. Old timing belts can skip a tooth, if that has happened to you, you need to replace the belt.
denisholden
03-24-2013 05:15 AM
burnindesirez02
04-21-2009 04:19 PM
Mario89
11-27-2006 09:31 PM
boostnub
11-08-2006 01:17 PM
skidbump
05-15-2005 08:53 PM
Quick Reply: problems with ecm or crank shaft positon sensor or both
