Some turbo questions please help!!!
Old 07-12-2006, 08:17 PM
Skrapdoggydog's Avatar
Default Some turbo questions please help!!!
I am installing a Drag Gen. 3 turbo system on my 95 civic EX with a B16A with no internal work. Do i need to have my ECU upgraded? bigger injectors? what do I need that this kit does not have?
Drag High flow 4 into 1 cast iron turbo exhaust manifold
- Turbonetics T4/T3 TO4E High flow turbocharger assembly
- Turbonetics Delta gate Mark II Wastegate (7 PSI Spring)
- Drag High Flow front mount intercooler w/ polished cast aluminum end tanks
- Blitz blow-off valve
- Drag mandrel bent high flow chrome plated pipes
- Drag mandrel bent high flow exhaust down pipe
- Drag wastegate dump tube assembly
- Drag Blue silicone hose and hose clamps
- Drag High pressure/High volume inline fuel pump
- Boost dependent FMU fuel regulator
- Intake air filter assembly
- Map sensor bypass valves
- Stainless steel braided oil feed line w/ fittings
- Oil return assembly
- All necessary hardware and fittings
- All necessary hose and hose clamps
- All necessary gaskets
- Installation manual
Old 07-12-2006, 09:59 PM
Tater's Avatar
Default RE: Some turbo questions please help!!!
well welcome make your way over to the turbo forum. and they will tell you all about them.
civicexracer's Avatar
WELCOME!
Old 07-13-2006, 01:02 PM
Im not too sure but I think you should get some internal work done in your engine before you turbo it.
oldguy
03-17-2007 01:03 PM
Inferno21
11-01-2006 04:34 PM
apexi_89
07-16-2006 02:23 PM
Skrapdoggydog
07-14-2006 10:34 AM
Quick Reply: Some turbo questions please help!!!
