check valve on a MAP SENSOR???
hey everyone
good news got he cat off and runs alot better boost went up to 4 1/2 rather than 2 with it on man does it pull
well i have been looking at some things with the map sensor cause thats what was triggering the check engine light and found a site concerning it as well. http://www.cse.uconn.edu/~yelevich/turbo/turbo.html if you follow the link you'll see him install a check valve on the map sensor, which allows for vacuum but not boost (which i found that MAP sensors dont like) to get to the sensor allowing everything to work properly. thought i would run this past everyone see if any one had heard of this before or if anyone else has a problem with this check engine light as i do
red_sleeper
red_sleeper
RE: check valve on a MAP SENSOR???
try the synaps ( i forget how to spell -its sounds like snaps) ive had it on my si for ever and the light never comes on.
about $75-$100 and it comes with extra stuff to clean it. goes between map and intake
good luck
turbo93si
good luck
turbo93si
where did you get it? is it pretty much just a block or spacer that bolts between the intake and the sensor and then like a check valve coming out of it to vent the boost? or is it in line with the vacuum hose? also on my 99 i cant find a hose that goes to it so does its take the reading right from the intake?
thanks
red_sleeper
thanks
red_sleeper
well i went to ebay and got one cause its exactly what my problem is, there is no doubt about it. now im just waiting on the MBC and then the MAP block and then be kickin some tail!!!
WWOOHHHOOO
WWOOHHHOOO
00sithrottle
05-12-2005 10:25 AM
00sithrottle
05-11-2005 10:18 AM
