Non-Honda Discussion Discussion of all other makes and models takes place here!
1980 VW Golf 1.6D project, or StifflersMom now is a Dubber.
Old 10-01-2013, 10:54 PM
StifflersMom's Avatar
Cat Fuсker
Well fuсker didn't start this morning. These things are sensitive to air getting into fuel system. The fuel return on the injectors is leaking.
Old 10-02-2013, 12:55 PM
alanking80's Avatar
ya got a good looking little VW there. No matter what you decide to do remember that the only one who has to like what you do is you. Be an individual and enjoy your ride and customize as you see fit. We'll be looking forward to seeing what you do in the future with it. Good luck
Old 10-03-2013, 02:49 AM
Cat Fuсker
Fixed the damn car with a kitchen knife (remember, all my tools did not go with me, all I have here is a SOG multitool, channel locks, and a screwdriver). Car started up pretty much immediately after cutting 1/4" from both sides of the injector fuel return hoses and stuffing them back in. Ordered 5 meters worth of return hose, some fuel line, some bushings for the shift mechanism to fix slop, new throttle cable, also ordered a manual inline fuel pump for priming the IDI pump when car has been sitting for a while. Since the expensive injection pump is lubricated by diesel fuel, when your system drains to the tank it has to pull fuel all the way from the tank while it is not getting any lube in itself. I've started putting in 2-cycle ashless engine oil as an additive and it helped with my idle, also hoping it is helping the pump. Have found out that my engine is a funny one. Engine code is 1V which comes from an ecodiesel car. Ecodiesel in this form is a turbo engine block with all turbo pistons, oil squirters, etc., with a turbo (previous owner converted car to NA), but with an NA injection pump. The turbo was a low pressure type with no "boost map", and supposedly was there to reduce smoke at hard throttle. The good news - all I need to go turbo is a turbo injection pump and the turbo.
Old 10-06-2013, 11:21 AM
Cat Fuсker
I bet you don't know what and why I did here.
No, the rubber thing is not a sex toy.
Old 04-27-2014, 09:09 AM
Cat Fuсker
Some of you really should check your brake calipers too. This is what my caliper looked like.
Old 04-28-2014, 12:24 PM
catch can back in October 2013. Didnt care enough before to post
Old 04-28-2014, 02:16 PM
Cat Fuсker
There is no catch can on the car man...
Old 07-31-2014, 05:19 PM
RiseAgain97's Avatar
MK1 droooollll
StifflersMom
11-21-2012 02:28 PM
StifflersMom
03-30-2010 06:04 PM
RonJ
02-26-2010 04:33 PM
StifflersMom
02-19-2010 08:22 AM
Quick Reply: 1980 VW Golf 1.6D project, or StifflersMom now is a Dubber.
