Routine Maintenance DIYs For all of your routine maintenance needs.
IACV Cleaning
Old 03-21-2008, 07:22 PM
GReddy_Civic's Avatar
Snail'n Admin
Default IACV Cleaning
I've been noticing that a lot of people are having problems with their car idle being irregular here on the forum. A possible cause could be a clogged IACV (Idle Air Control Valve). To fix this problem is very simple.
Tools Needed: 12mm socket and wrench
Brake or Carb Cleaner
Philips Screwdriver
Old rag to help with overflow from heater lines
First, locate the IACV. It's in the back of the engine bay by the intake manifold and throttle body. I have circled it below (should be located here for most, if not all, D and B series).
The next step is to loosen the two 12mm bolts that hold it on.
After removing the two bolts, unplug the electrical connection and also the two hoses leading into the IACV. Take the old rag to keep from the fluid in the heater lines from spilling everywhere. *Note- If you are having problems with the hoses being stuck, spray some WD40 or other lubricant on them and it is a wise idea to also replace the clamps on the hoses due to the fact that they will never work as well after this* You should now have something like this.
As you can see, my screen is a tad bit clogged up. Take the brake or carb cleaner and spray it on the screen. Leave sufficient time for this to dry before reinstalling it. You should have something like this.
While you have this piece off, you can remove these screws to make sure the gasket underneath is still in good condition, and in my case it was.
Installation is the opposite of removal. Once you have it reinstalled, start it up to make sure it runs! Hope this helps.
Old 03-21-2008, 07:51 PM
Mr Mobsta Man's Avatar
Default RE: DIY: How to Clean Your IACV
Nice writeup [sm=smiley20.gif]
Old 08-27-2008, 08:06 AM
kellydane20's Avatar
where is the IACV on a D15B2??? i cant find it anywhere and its not in the back of the IM
Old 08-27-2008, 08:33 AM
My04Civic's Avatar
Administrator
nice writeup bro
jlor010
08-08-2010 06:21 AM
faifu27
05-29-2010 05:19 PM
jamisonh
02-21-2009 10:17 AM
rcalimquim
12-07-2007 04:20 AM
psychocivic
11-04-2006 07:25 PM
Quick Reply: IACV Cleaning
