Rear Drum Brake Shoes Replacement - HondaCivicForum.com
Closed Thread
Old 03-26-2007, 01:27 PM
Administrator
Default Rear Drum Brake Shoes Replacement
Rear brakes. A short course in replacement.
What I have is a 97 civic ex, 195,000 miles, disk brakes up front, and drums out back.
I'm doing my rear brakes for a couple reasons; first and foremost I feel a pulsing in the brake pedal but not in the steering wheel. So it can't be the front brakes, and secondly, in the 100,000 miles that I've had this car, I've never done the rears.
This is not intended to be the end all is all instruction set. But this should give you a good idea of what it takes, and that you can do this yourself with basic hand tools, and a couple hours in the driveway.
What your gonna need
New brake shoes to fit your car
A spring hardware kit
Brake cleaner
A flat screw driver
Lug wrench
Jack
Jack stands
Pair of needle nose pliers [/ol]
You may also need, depending on your particular needs and wear on the vehicle:
Rear hub assembly (for my car, this comes with new wheel studs, the hub, bearings, and a rear hub seal)
New hub nut
New drums (if yours are worn, not round, or have too much wear to be turned)
High temp paint (not necessary, but I thought it would look good)
New wheel cylinders
New hub nuts
Torque wrench
Socket to fit hub nut [/ol]
So it's off to the rears.
First, jack the car up and securely support it on jack stands.
Then pull the rear wheels off.
This is what you should basically see.
I have inserted 2 8mm bolts into the holes in the drum, cause I know that these puppies are gonna be tough to get off.
Screw the 2 bolts in and going back and forth between then, turning them about 1 turn each time, continue till the drum comes loose from the hub.
Pull it off and put it aside.
Now look at the wheel cyl, it's the metal tube thing at the top. If it's wet, you will probably want to replace it. Its leaking brake fluid.
Now for a word of caution, brake dust can contain all kinds of nastiness, and I strongly suggest that you not blow the dust off with compressed air, it will clog up your nose, and can make you very sick. My suggestion is to use a can of brake cleaner. Spray it all down, this way your not gonna end up breathing in that dusty crud.
I just used the cheap stuff from my local auto parts place.
Spray down the brake assembly, but keep this stuff off any rubber parts or painted parts, this is pretty nasty stuff in its own right, so don't get it on your skin or in your eyes. it burns like a ***** in the eyes!!!
I suggest getting some el cheapo rubber gloves from harbor freight or where ever. And use your hand to cover the wheel cyl. It has rubber boots that can be damaged.
I also suggest getting a drain pan and putting it under the assembly to catch all the crud, this way the neighbors wont call the EPA on you! Hehe. The liquid will evaporate pretty quickly.
Now, I suggest inspecting the drum, if you see deep grooves, or a lip on the inside edge, then I suggest having them turned at your local auto parts place. most will do this in about an hour for about $8 each. or you can do what I did and just replace them, cause I don't think mine are round anymore. they could probably be turned, but I wanted to paint them anyway, and new ones are much cleaner.
Grab hold of the hub and push and pull and rock it side to side, and spin it and see if you feel any slack, rubbing, grinding or if you hear anything. any of these would be an good indicator that you should look into your wheel bearings.
Now, look at the old shoes, and see if they are thin, grooved, or maybe even missing chunks. if any of these are the case, replace them. Its cheap and after reading this, pretty easy. you can use the new shoes as a thickness guide. if you see shiny metal around the surface of the old shoe, then their really gone. and have probably been chewing into the drums. Shame on you for not doing this earlier!
Now you have a choice. if your wheel bearings are ok, then you can do this job without taking the hub off, if your bearings are in need of replacement, pull the hub off now, it'll make the rest of the job easier. you can pull the hub off just to make the brakes easier, but you will need to replace the hub nut when you put it back on. it's a cheap part, so please don't reuse it. this is what holds your wheel on, if it were to come loose while your going down the road/track/ whatever, it could be bad, really really bad.
To get the old shoes off, use the flat blade screw driver to push on the retainer springs and turn the retainer studs so that they come out of the springs. Throw the springs and studs away, there are new ones in your spring hardware kit. The studs come out of the backing plate, with a little wiggling and getting that pinched flat end through a little hole.
Now that you have the retainers out of the way you need to swing the bottom of the shoes out of their retaining mounts. I used a flat blade screwdriver to help me with this.
Now that you have the 2 bottoms out you will need to wiggle and finagle the shoes, adjuster assembly, old springs and all out. I did this by taking the bottom spring off of the shoes, and gently separating the bottoms till I could swing then out and over the hub.
One thing that you will want to be aware of is that the e-brake cable is still attached to the bottom of the rear most shoe. This will make getting the assembly out a challenge. But it can be done.
Once you have this mess out and hanging by the e-brake cable, disconnect the e-brake cable by pulling the e-brake spring away from the shoes and sliding the cable end out of the slot.
Now lay the whole thing on the floor and disassemble. pay attention to where the adjuster is, and which way the long and short arms of it are. this must go back in with the gear ring towards the front of the vehicle. And one arm is longer than the other. If you don't get these parts back in like their supposed to be then the rear brakes wont auto adjust. Continue to disassemble, taking the horseshoe retainer clip off the rear shoe and tossing the clip, there a new one of these in your hardware bag.
Keep the stud that goes through the shoe, and the little springy washer and e brake actuator arm that comes off.
Take the old coily springs and toss them. Pull the end of the adjuster off, and wipe the entire thing down. get all the crud off of this.
Now, go wash your hands you filthy person. The reason for this is that you don't want any old grease or crud on your new pads. Grease and oil can soak into new pads and cause them to wear out faster and not provide proper breaking force.
Take the new long spring, short spring, horseshoe clip e brake arm, stud, springy washer, adjuster actuator, and 2 new shoes out and lay them out in front of you. assemble the e-brake arm to the rear shoe, just like it came off, making sure to use the new horseshoe clip. once you get that on, give the open ends of the clip a good squeeze with your needle nose to make sure its pinched on there real good, and down in the groove of the stud.
Put the adjuster actuator and spring on the front shoe, just like they came off. Now take the long spring, in my case it was green, and put it in with the longer straight end towards the shoe that
Closed Thread
Thread Thread Starter Forum Replies Last Post
Rear drum brake adjusters won't adjust gkitf16 Suspension, Brakes, Tires & Wheels 4 01-01-2009 10:28 PM
2004 Civic EX Rear Drum Brake Conversion spatuality Suspension, Brakes, Tires & Wheels 4 07-02-2008 07:16 AM
REAR BRAKE DRUM RUB HONDASENCE76 Mechanical Problems & Technical Chat 8 02-24-2008 03:04 PM
Rear Brake Shoes Rhood Suspension, Brakes, Tires & Wheels 0 01-11-2007 05:14 PM
How to remove rear brake drum??? phearly Suspension, Brakes, Tires & Wheels 12 11-13-2006 12:20 PM
Tags
97, bottom, brake, brakes, civic, drum, honda, hub, loose, nut, rear, replace, replacement, shoes, spring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
