Lowering 2"-Camber Kit Needed?
Old May 9, 2008 | 12:48 PM
Default RE: Lowering 2"-Camber Kit Needed?
well with a alignment id say dont have it EYE BALLED!!!!!! get it up on a real alignment rack where a computer will make it almost perfect!
Old May 9, 2008 | 12:49 PM
^ yeah, I was going to mention that if you went low enough, zero camber could actually cause you to rub (for instance, I'm tucking tire on all four corners... that wouldn't happen with 0* camber)... but he said no more than 2", so I don't see that being much of a problem.
Old May 9, 2008 | 12:55 PM
BuckHijo's Avatar
ORIGINAL: croninc
just depends what size rims you got an how low you really want to go and 2inch shouldnt be that big of a deal
Right now I have 17" rims but I was thinking of going to 18" rims. Is that 1" deffernce going to be a big deal for my alignment?
Old May 9, 2008 | 01:04 PM
I wouldn't recommend going with 18's if you're lowering. It's not the offset that's going to hurt you so much as it is the fact that 7.5-8" wide wheels will rub pretty much no matter what on a 7th gen or older civic.
Old May 9, 2008 | 08:35 PM
BuckHijo's Avatar
ORIGINAL: addiction2bass
I didn't mean to give the wrong idea but I was not planning on "eye balling" it. I will have have it on an alignment rack and do it right.
Old May 9, 2008 | 10:10 PM
ej6buddy's Avatar
well, a camber kit is not critical, but if you want your car to be a little safer as well as adjustable for the future (b/c of your coilovers) while a slight toe-in in the front will compensate for the dropped geometry, it will still produce a good bit of drag, therefore hurting your car, gas mileage, tires, as well as performance. so in my opinion, a $300 camber kit is a cheap investment, especially if you like to adjust it yourself and to make it easy on the alignment shop as well!
p.s. the washer trick should only be used with extended high strength bolts of the same size. just as a safety precaution to retain those extra threads on the bolt.
Old May 12, 2008 | 11:16 AM
davin_t's Avatar
yes your going to need one. ive been through 3 alignments and my 01 civic still has a camber. be carefull where you go!
Old May 12, 2008 | 02:47 PM
your camber isnt to important. the TOE is the worst!
no way to correct camber without a camber kit so you can get a million alignments unless you have a camber kit to properly adjust it then they cannt fix it.LOL your just wasting money!
camber only slightly wears the tires but it does evenly wear it....
but toe will destroy the inside of the tire down to the steel belts quickly!
Old May 12, 2008 | 04:31 PM
ej6buddy's Avatar
and the thing about it is...you can only correct the negative camber with a slight toe in, so therefore it's still gonna wear your fronts out unless you set the camber with a kit back to factory settings so then you can ride zero toe with no worries.
rags2richs
Nov 16, 2007 12:48 PM
Jedikid
Sep 29, 2007 09:51 PM
D16Punk
Mar 30, 2007 11:44 PM
tools52
Jul 21, 2006 08:41 PM
Clean98EX
Aug 21, 2005 03:15 PM
