cigarate lighter wont work
Old Jul 24, 2010 | 12:33 AM
honda09's Avatar
Default cigarate lighter wont work
well my cigarette lighter wont work. i dont know why i have checked the fuses and the wiring. well not really the wiring since i can only go so far, i would really like to get this working since i have a gps all ready for it
Old Jul 24, 2010 | 11:55 AM
honda09's Avatar
well the wires only go to this plastic tubing that you would have to break in order to check all the wires behind it.
Old Jul 29, 2010 | 08:26 AM
Check right where the wires connect to the back of the socket, that's where the problem would be. Use a meter or test light to be sure the center wire is live (if not, go back and check if both ends of the fuse are live), and the outside wire is grounded. Remember that you have to turn the key on to energize the circuit.
Old Jul 29, 2010 | 08:34 AM
N0safebetdx's Avatar
shawty
haha mine doesnt work either but I have no use for it anyways so i just left it not working...
Old Aug 2, 2010 | 02:02 PM
mouserace2010's Avatar
It has to be the fuse. I had the same issue and got it fixed
Old Aug 2, 2010 | 04:00 PM
milhouse's Avatar
cig lighters should be constantly on? they are wired straight off the battery. if it doesnt work just look for an empty connector on the fuse panel and wire it to the lighter.
Old Aug 2, 2010 | 11:02 PM
supersize's Avatar
Sir Banned-a-lot
my cig lighter isnt always on, i have to have they key turned to acc or have the engine on in order for mine to work
Old Aug 3, 2010 | 07:16 AM
I think that's the case with all Civics, stock wiring is such that the lighter is only energized when the key is on. Most Toyota, Subaru, and other Japanese brands are the same way.
Old Aug 4, 2010 | 08:49 PM
milhouse's Avatar
not i my civic(never checked), but in my dads older cars, they were on all the time. i wired one up im my old truck straight off the battery, must have been a fire waiting to happen. hows someone supposed to lite a "cigarette" without the keys????
