wtf is up w/ this
Old Sep 12, 2005 | 06:04 AM
SkItZiAnIsT's Avatar
Default wtf is up w/ this
ok i have a hi-flow cat and when im driving down the road w/ my foot even on the gas, it will cut back, like it is restricting something (losing about 3-5mph in the process), and then it will stop, and i will get a boost (about 3-5mph) this also use to happen w/ the test pipe i was running, but not as often
i think it may be the 02 sensor, but i'm not sure, anyone else have this problem?
Old Sep 12, 2005 | 04:46 PM
PhilStubbs's Avatar
Default RE: wtf is up w/ this
sounds like o2 to me
Old Sep 14, 2005 | 05:27 AM
so should i make a "dead 02 sensor" w/ a spark plug? my friend at work knows how to do it...
Old Sep 15, 2005 | 05:02 PM
PhilStubbs's Avatar
i would just get a new one, its not a good idea to drive around w/o your car knowing its oxygen level
Old Sep 15, 2005 | 06:55 PM
neon3kgt's Avatar
what year is it?
Old Sep 15, 2005 | 06:56 PM
Remmy's Avatar
You wouldnt happen to have an auto would you? Becuase I get that same senation. And come to thin of it, yea my o2 is bad also : )
Old Sep 15, 2005 | 08:03 PM
PhilStubbs's Avatar
my keen dtective abilities tells me that his car is a 99 and a manual. how do i know you ask? simple watson, in his signature it says "99 Honda civic HX" and it also says "JDM short throw (still to install)"
but i still say just spend a few bucks on an o2 sensor
Old Sep 15, 2005 | 08:35 PM
315 Customs's Avatar
you should become a detective PhilStubbs. you are da man!
Old Sep 16, 2005 | 12:38 PM
yeh im not putting it in i heard that the aluminum snap w/ in less than a month, why would it matter if it cant detect the 02
Old Sep 17, 2005 | 08:04 AM
PhilStubbs's Avatar
ORIGINAL: SkItZiAnIsT
the reason your car is running bad is cause it has no idea how much fuel it needs to run right. the o2 sensor tells it how much unburnt oxygen is in your exhaust and adjusts the fuel amount. if you trick your car into thinking it has the right amount but it really doesnt then you could cause some serious problems
