burning oil
Old Sep 24, 2005 | 12:53 AM
whitehonda's Avatar
Default burning oil
I have a 94 honda civic that has 170,000 miles on it. After a few months of owning it, it started to burn a lot of oil. I just replaced the cylynder head after the old one went bad. Now it burns a lot more oil, worse than before. I was wondering if you might no whats wrong with it or what I can do to fix the problem.
Old Sep 25, 2005 | 08:58 PM
riceburner700's Avatar
Default RE: burning oil
your piston rings could of taken a crap on you and you are getting a lot of blow bye with the oil scraper rings not doing there job, by scraping almost all of the oil that was thrown from the crank onto the cylinder wall back to the oil pan but that is my guess is that your piston rings in a couple of pistons took a crap[sm=icon_cheers.gif]
Old Sep 25, 2005 | 09:28 PM
ngoti 8tor's Avatar
I concur.
Old Sep 25, 2005 | 11:13 PM
StifflersMom's Avatar
Cat Fuсker
Sure sounds like the rings are fried...are you sure the head you put on is good?
Old Sep 26, 2005 | 02:15 PM
Kappa22's Avatar
Your rings are definitely shot, and it sounds like either your cam seal is leaking, or (if there's no leak) the valve seals in the new head are crap.
Old Sep 26, 2005 | 05:59 PM
neon3kgt's Avatar
do a wet and dry compression test.... if its higher when you put some drops of oil in the cylender then before, then its your rings...
Old Sep 26, 2005 | 10:44 PM
spanky91's Avatar
yea id say ur pistons and rings are shot mine is about to go and i have 230k on
so yea id sAy go get your self a new motor
Old Sep 30, 2005 | 10:21 AM
91crx_87's Avatar
id say that neon3dgt has it right, sounds like piston rings to me.
Old Sep 30, 2005 | 11:37 AM
Kappa22's Avatar
The fact that it got worse after the headswap is what makes me think that the valve seals in the new head could also be shot.
Old Oct 30, 2005 | 10:19 PM
jwsimons's Avatar
hey, kappa. please go into more detail on the valve seals..
ORIGINAL: Kappa22
