NX or NOS??
Old Sep 30, 2005 | 06:27 PM
Chimera02EX's Avatar
Default NX or NOS??
I'm looking at 2 nitrous systems, both are wet style:
NX System:
NX EFI single nozzle kit w/ air intake tube style delivery up to 250hp, 15lb bottle, microswitch activation
jet sizes vary by engine displacement
Part #: NEX-20923-15
NOS System:
Sportsman Fogger intake mainfold style derlivery up to 250hp, 15lb bottle, microswitch activation
50, 75, 100, 125, 150 jet sizes
Part #: NOS-05030FI15NOS
Ok so they are basically identical except for the delivery style, so my big question is which style is better, air intake or intake manifold???
I should add that the prices only vary by $15 bucks so price isnt a factor here.
Old Sep 30, 2005 | 06:44 PM
Nail I3unny's Avatar
Default RE: NX or NOS??
mm...peice a nitrous system together yourself. just make sure to use NOS solenoids
like a turbo kit...a nitrous kit will be more expensive than peicing a system together yourself
Old Sep 30, 2005 | 06:49 PM
So which style of delivery should I look into? air intake or manifold?
Old Sep 30, 2005 | 06:58 PM
btw...the reason i say NOS solenoids is because NX are known to fail...but in general NX solenoids will last longer
it doesnt really matter which one you go with...theyre both 'wet' setups
Old Sep 30, 2005 | 07:00 PM
ahh ic so theres really no advantage to either delivery system because they are both wet?
Old Sep 30, 2005 | 07:05 PM
more or less the same. btw dont take my information as fact...but im pretty sure im pointing you in the right direction. i am by no means an expert on nitrous
Old Sep 30, 2005 | 07:11 PM
I started building a kit, and the price got close enough to the actual kit price that I'm just gonna pick up a kit, I'm a complete newb when it comes to nitrous so I'll fork out the money for a kit, makes sure I get everything I need. This is still a year away at least, but I'm the kind of person that needs to plan things out to completion or I won't get anything done.
Old Sep 30, 2005 | 07:28 PM
just make sure you do some research before getting a kit. i havnt researched it much myself because i dont plan on putting nitrous onto my current car. its prolly gunna be on one of my future cars tho
Old Sep 30, 2005 | 08:16 PM
I've done my homework, I'll prolly get the kit before I do my bottom end engine internals so I'll run 75 shot, after I get bottom end I'll up it to 125, then once I sleeve it, 200-250.
Old Oct 9, 2005 | 03:45 AM
US3R!!!11one's Avatar
Here you go:
1. Fuel solenoid (NX or a large NOS)
2. Nitrous solenoid (NX or a large NOS)
3. Solenoid mounting brackets (Ebay)
4. Plate (Ebay)
5. Jets
6. Braided line from solenoids to plate
7. Fuel pressure safety switch
8. Nitrous pressure gauge
9. Fuel pressure gauge
10. Braided line to trunk
11. 10 lb bottle (Ebay)
12. Blow down tube (NHRA requirement)
13. Bottle brackets (Ebay)
14. Bottle warmer
15. Various AN fittings
16. AN fuel filter
17. AN nitrous filter
Optional:
Remote bottle opener (useful for running nitrous on the street)
Purge (useful for consistent runs)
[edit]Almost forgot to answer your question. A wet kit is basically the exact same as a Direct port, it just branches off into 4 jets instead of one. Theres really no excuse to not do a direct port other than just being lazy =) You can also inject the nitrous directly into the injectors with some setups.
