Wet Clutch?
Old Oct 28, 2005 | 09:07 PM
Toppers's Avatar
Default Wet Clutch?
Ok, I'm familiar with motorcycle clutches where we basically have two kinds: wet and dry. Wet clutch shares the same bath of oil as the transmission, and the rest of the engine too. What about Civics, how are our clutches lubricated, the same way?
Old Oct 28, 2005 | 10:06 PM
AOL.COM's Avatar
Default RE: Wet Clutch?
i'd say automatic trannys are wet clutches & standards are dry clutches
Old Oct 30, 2005 | 06:24 PM
Kappa22's Avatar
If you're lubing up your clutch, you won't be going anywhere fast... Autos don't use "clutches," per se; they use torque converters.
Old Oct 30, 2005 | 06:26 PM
Pete's Avatar
yea and they suck.
honda 5 speed uses 10W 30 motor oil
auto uses tranny fluid
Old Oct 30, 2005 | 06:28 PM
Kappa22's Avatar
But the 10w-30 doesn't actually ever touch the clutch... All trannies need lubrication, but clutches need friction.
Old Oct 30, 2005 | 06:30 PM
Pete's Avatar
I thought he wanted to know what to put inside to lube it up.
Old Oct 30, 2005 | 07:21 PM
Toppers's Avatar
No, I'm asking what lubricates the clutch in our cars--not the transmission itself.
Old Oct 30, 2005 | 07:26 PM
Kappa22's Avatar
Nothing. A lubricated clutch disc would not be able to generate friction, and therefore somewhere in the neighborhood of 0% crank power would be transferred to the wheels.
Old Oct 30, 2005 | 07:27 PM
Pete's Avatar
yea it wouldnt be able to "grab" the gears
Old Oct 30, 2005 | 11:49 PM
99civic_boosted's Avatar
ORIGINAL: Kappa22
Actually auto's do have what is called "clutch packs".
