EG Swaps 1992-1995 Civics
eg b18b swap
Old Nov 20, 2005 | 11:44 PM
SIBuddy's Avatar
Default eg b18b swap
i have a 94 integra with a b18b in it and a eg shell i want to take the motor out of my integra and drop it into my civic do i need any extra parts or would everything be all their?
Old Nov 21, 2005 | 12:13 AM
Default RE: eg b18b swap
should all be there if both cars are complete. youll probably need a few new things, like axles. and a new timing belt and water pump are a lot easier to install when the engine is sitting on the floor, vs installed in the engine bay. same with a new clutch.
Old Nov 21, 2005 | 10:23 AM
SIBuddy's Avatar
cant i use the axels and water pump from my integra i understand the timing belt tho
Old Nov 21, 2005 | 02:13 PM
cdiddym's Avatar
yeah i think so also
Old Nov 21, 2005 | 05:24 PM
SIBuddy's Avatar
so i have everything for the swap is it possible to keep the same timing belt on to one more thing my integra is a 2dr will the exhaust system fit on or will i have to mod it for the eg hatch
Old Nov 22, 2005 | 12:31 AM
yeah, you can use the teg stuff, its just that it will fail at some point, and so it is a huge timesaver to just replace them while the engine is out. if you cant afford to buy the parts now, wait till you can. if you can afford a timing belt and water pump, you dont want to tear into your car, because things come up that will need replacing. i made that mistake on my first swap, and once i got it running , i backed it out for the test drive, and coolant was pouring everywhere, so i had to pull it back in and wait a couple of days for a new waterpump and t belt, then take yet another day to install it. then after a couple of months of driving it with the swap, the clutch disc came apart, and i was up until like 2 am replacing it so i could get up at 5 am to go to work. trust me, its well worth the cost to just have those things out of the way.
Old Nov 22, 2005 | 12:41 AM
Pete's Avatar
ORIGINAL: sacicons
wow i thought i was the only one who that kinda crapola happend to
Rsporty
EG Swaps
Feb 7, 2010 06:01 PM
nicko360
Jan 8, 2007 06:10 PM
jspec95
14
Jan 29, 2006 04:07 PM
jspec95
Jan 16, 2006 08:06 PM
HondaCivic777
May 2, 2005 10:57 PM
