Need an answer quick
Old Dec 17, 2005 | 09:19 PM
XCM828's Avatar
Default Need an answer quick
How do you get off the oil pressure sending unit?
Old Dec 17, 2005 | 09:21 PM
riceburner700's Avatar
Default RE: Need an answer quick
should just unscrew from the back of the black pull off the rubber cap first and then use a deepwhel socket on it
Old Dec 17, 2005 | 10:08 PM
XCM828's Avatar
I can't seem to get that black cover off. My hand is cramping up like crazy.
Old Dec 17, 2005 | 11:16 PM
ExospeedRacing's Avatar
yup its a bitch sometimes. The rubber is all hard and tends to just break off cuz its all dried out.
Old Dec 17, 2005 | 11:23 PM
you buy any chance dont have some spark plug wire pullers that look like some tongs.... try those if you are having a tough time getting to the back of the block
Old Dec 17, 2005 | 11:24 PM
orrrrrrrrr just find some kid with smaller hands.....lol
Old Dec 17, 2005 | 11:27 PM
Pete's Avatar
i just used lots of WD40 and elbow grease...........
Old Dec 18, 2005 | 11:42 AM
skytanker2003's Avatar
Sounds like he was 'bout to run out of grease though...XCM, you get it yet?
Old Dec 18, 2005 | 01:25 PM
XCM828's Avatar
Not yet, but since last night I haven't really tried. I mounted the turbo and manifold to the engine, but the compressor housing is touching both the radiator fan housing and the a/c compressor hose. The fan housing i can just cut to make room, but the a/c compressor is already pushed back a couple of inches from where it should be? Is it ok for it to be touching?
Old Dec 18, 2005 | 04:13 PM
XCM828's Avatar
Woo got it off finally. My fingers hurt like no other because its really cold out (for this area at least). Only got a little left to do. Gotta tap the oil pan, hook up the downpipe, hook up the MSD and the MF2, do all the vacuum routing and put in my oil.
