Interior Light Problem.
Old May 7, 2004 | 05:44 PM
NTX's Avatar
NTX
Default Interior Light Problem.
My dome light <U>only</U> comes on if i <U>manually switch</U> it on. I would come on if the doors were opened or when i disarmed my alarm system. I checked the fuses under the dash and under the hood and they all check out. I know the door switches still work because the alarm works if any door is opened. </P>
Any thoughts?</P>
Old May 7, 2004 | 06:44 PM
iNTRuDeR's Avatar
It wouldn't be the fuses or you wouldn't have the light at ANY time.</P>
Check the contacts on the switch itself,</P>
Also check that the ground is good on the light itself.</P>
I'm not sure if the circuit grounds the light of not to make it light, but I've had bad connections in the dome fixture itself do similar things.</P>
</P>
</P>
</P>
Old May 7, 2004 | 06:56 PM
NTX's Avatar
NTX
I'm gonna check it now. What sucks is i know it's something simple...i just can figure it out.
Old May 7, 2004 | 10:32 PM
NTX's Avatar
NTX
No luck andI really dont want to pay someone to look at something so small.</P>
Old Jan 20, 2006 | 02:40 PM
jtrisler's Avatar
Default RE: Interior Light Problem.
I have the same problem with my civic. Did you ever figure out what the problem was.
Thanks
Old Jan 20, 2006 | 04:31 PM
Raul98's Avatar
if u have an after market radio maybe the jumper came off?
Old Jan 20, 2006 | 10:05 PM
Esquirrel's Avatar
i actually have the same problem..and I ALSO installed an aftermarket radio
Old Jan 21, 2006 | 12:09 AM
Pete's Avatar
you sure the door switches arent just stuck? Check em.....the little rubber boots....the alarm may have a different switch....if not id try somethin stupid, like get a new bulb.......its going to be somethin stupid.
Old Jan 21, 2006 | 09:04 AM
Raul98's Avatar
theres 2 green wires one has a black line and the other a red or pinkish color one it should be on the smaller of the 2 remaining plugs. Jump those 2 wires with a wire thats a lil thicker in gauge size and your problem will be resolved. I just installed my system on my 98 and after jumping the 2 wires the dome light worked when I opened the doors. You alarm will also not trigger if ur dome light those not go on when u open the doors so get that working ASAP
Let me know if you have any questions and I will snap some pics of it and post'em.
good luck
Old Jan 21, 2006 | 11:15 AM
XCM828's Avatar
Jeezis talk about a thread from the dead. This ones from like a month and a half after the forum was created.
