help with timing
Old May 9, 2004 | 06:03 PM
alexander's Avatar
Default help with timing
I'm doing a timing job on my '89 LX and I can't find the timing marks to aline the cam and crank. I just did this on an '85 prelude, but the marks don't appear to be in the same place. My manual says that they are on the pulley, but i didn't see any. Thank youfor your time and any help
Old May 9, 2004 | 09:32 PM
lilol89crx's Avatar
the cam pulley says up, that is your cam timing mark with the #1 piston at tdc.
Old May 10, 2004 | 11:24 AM
polo708's Avatar
nicely put... what he said.<IMG src=smileys/smiley2.gif border="0">
Old May 11, 2004 | 02:04 PM
alexander's Avatar
But how do i tell when the #1 piston is at TDC? The other honda I did this on had marks between the engine and trans to line up exactly. Thanks for your help
Old May 19, 2004 | 11:07 AM
sasquatch's Avatar
alexander, you can tell when #1 is at TDC by removing the distributor cap and looking at the rotorbutton. If it points to the HVwire on the cap going to #1 sparkplug then #1 piston is at TDC. If it is 180 deg. out then you are on the exhaust stroke of # 1 and have to keep turning until the engine until it points to #1. It is best if you had a manual - they explain it all in detail.</P>
All this assumes that you have not fiddled with the distributor.<IMG src=smileys/smiley1.gif border="0"></P>
smackpower
Jan 13, 2024 01:42 AM
crxlvr
Jul 28, 2005 02:10 AM
crxlvr
Jul 27, 2005 02:08 AM
Jas10hon
Jul 4, 2005 10:35 PM
forcefedcivic27
Sep 12, 2004 08:06 PM
