tps sensor wiring
Old Jan 18, 2006 | 02:53 PM
ef4life's Avatar
Default tps sensor wiring
i have a question. i did a z6 swap in my ef and used a conversion harness to convert to obd 1. the only problem i have is with the tps sensor. the instructions said to swap the two outer wires on the sensor plug to make it work right. i was just wondering what colors and in what order are the three stock tps wires because i think i might have them switched around in the wrong order, and if they are in the wrong order would i need a new tps sensor because it might be damaged from the reversed wiring. thanks a lot everyone
right now i run the car without it plugged in, it runs fine without it except for the CEL, but with it plugged the idle goes up and down
Old Jan 18, 2006 | 11:49 PM
Kappa22's Avatar
Default RE: tps sensor wiring
You need to switch the green/white and yellow/white wires. They should be on the outside of the plug.
Old Jan 19, 2006 | 01:42 AM
Pete's Avatar
its nuts how he knows this garbage off the top of his head.
Old Jan 19, 2006 | 02:00 PM
ef4life's Avatar
but i was wondering what colors the stock wires are and in what order were they before you are supposed to switch them.
Old Jan 20, 2006 | 01:19 AM
Kappa22's Avatar
They're still the same colors... Just backwards.
Old Jan 20, 2006 | 11:36 AM
ef4life's Avatar
so the wires are the same colors, now i need to know what order to put them in like from left to right. i have the order of them mixed up so i don't know which wire goes were.
Old Jan 20, 2006 | 12:11 PM
finalimpact's Avatar
pic taken with the retaininer side of the clip facing the firewall. wellow,red,green. pic from my 88 si hatch. your yellow and green should be opposite of mine being your a dx.
Old Jan 20, 2006 | 12:19 PM
ef4life's Avatar
thank you so much for the pic. one more question, if i had them hooked up wrong would i need to get a new tps sensor?
Old Jan 20, 2006 | 12:47 PM
nope at least i didnt. my firsst mpfi conversion i failed to swith the outter wires around. no damage for me.
Old Jan 20, 2006 | 10:00 PM
Kappa22's Avatar
Damn you and your camera...
And no, it won't do any damage to the sensor, but your engine will think you're at WOT when you're idling.
