Check out my new Civic...lots 2 do!
Old Feb 6, 2006 | 06:47 PM
yaserkali's Avatar
Default Check out my new Civic...lots 2 do!
IdeaS? Im thinking 17s, 40mm drop - ur ideas?
Also - wana get 12v power from car battery into interiro for blue neon rods - where can I get the wire through?? the whole under the dash with exisitng wires has rubber inside it and real tight - alternatives???
Thanks
Old Feb 6, 2006 | 07:07 PM
ef4life's Avatar
Default RE: Check out my new Civic...lots 2 do!
i like the car a lot, the 40mm seems good, i am not a fan of 17's i think 16 is the max. for the neon idea, you could splice into you cigarette lighter wiring and not have to go through the firewall, but you might overload the circuit if you use a lot of neons and also use the cig lighter at the same time. so you could install larger dia. wire from the fuse block to the lighter and SAFELY install a bigger fuse, without worry of starting a fire.
i mean safely because if you just put a higher amp fuse with small wiring, the current draw could overload the wires and cause a fire, so larger wires can handle more current and a bigger fuse if needed
Old Feb 6, 2006 | 08:02 PM
00 Ess Eye's Avatar
drop and 16's would look nice. welcome
Old Feb 6, 2006 | 09:15 PM
Cutt's Avatar
Welcome to HCF. Good luck with your project.
Old Feb 6, 2006 | 11:29 PM
riceburner700's Avatar
what color rims were you thinking?
Old Feb 7, 2006 | 01:42 AM
97_nw's Avatar
i like that car color..props! welcome.
Old Feb 7, 2006 | 10:35 AM
mill$civic's Avatar
welcome to the forum!..go with the 17" and drop
Old Feb 7, 2006 | 11:13 AM
Toxxic's Avatar
i have an exhaust im trying to get rid of for 200+s/h.
its not a great brand but its almost brand new, check out my f/s thread.
Old Feb 7, 2006 | 03:45 PM
domestic disturbance's Avatar
Welcome, I like the color too...I'd go 16's & the drop.
Old Feb 7, 2006 | 04:36 PM
usmc2b2004's Avatar
Welcome Yea the colors unique
