Need help about tire size???
Old Feb 14, 2006 | 12:07 PM
2002coupe's Avatar
Default Need help about tire size???
I just bouth some 17" wheels for my 2002 civic coupe and I was wondering if my tires were the right size ?I got some 215/40R17/.
Old Feb 18, 2006 | 01:41 AM
95CIVICUS's Avatar
Default RE: Need help about tire size???
what is the width of the rim? is it 7", 7.5" or 8"
if it is 7 you will ned 205/40/17
if it is 7.5 you will nedd 215/40/17
if it is 8 you will nedd 225/40/17
Old Feb 18, 2006 | 01:44 AM
neon3kgt's Avatar
i would go with 205/40... anything wider and you have a chance of rubbing.
Old Feb 18, 2006 | 02:07 AM
NTX's Avatar
NTX
moved to tires and wheels
Old Feb 21, 2006 | 07:29 PM
TorGa3iGhT's Avatar
I believe 7th gen civics have a larger wheel well, so you may be able to go with 215/45...stll depends on what kind of drop you are looking at though...you MAY run into rubbing issues...i'd check out 7thgencivic.com. they have a lot of specific information about your civic that you may find useful
Old Feb 22, 2006 | 01:12 PM
baker's Avatar
Old Feb 22, 2006 | 08:52 PM
riceburner700's Avatar
i would just go with the 215/40r17's that you have, they will work just fine
Old Feb 23, 2006 | 06:16 PM
2002coupe's Avatar
Ok thank's guys !!How could I post a picture of my rims and tire ??I would like to get your opinions
Old Feb 27, 2006 | 10:04 AM
KarTuneMan's Avatar
Look on the back side of the wheel....there will be some info there that is VERY important. Size (17x7.5) and offset (+40mm) Its hard to imagine that a couple of mm could/would make a diff. The offset is the key. If the wheel is 7.5 wide the offset you need is NO LESS than +42mm. If the wheel is 7.0 wide you can maybe get away with a +40, NO LESS than +38, or they will hang out too far. Ideal for your civic (fits just like stocks) is 17x7 +45mm. You can lower the car as far as you want. (within reason of course)
Old Feb 27, 2006 | 07:06 PM
2002coupe's Avatar
OK thanks .My rims are 17x7 with a 40mm offset . What to you think ?
