B18A1 Non Vtec to Vtec
Old Feb 20, 2006 | 12:32 AM
ryantann's Avatar
Default B18A1 Non Vtec to Vtec
I bought a 1990 Acura Integra GS with a B18A1 with a Non Vtec head. And I was wondering Which Head from the B series I can swap it out with to make it Vtec. Plus I plain to swap the engine in to a 89 CRX, how much trouble would that be, and what do I need to do the swap.
Thank You!
Old Feb 20, 2006 | 05:47 AM
jwsimons's Avatar
Default RE: B18A1 Non Vtec to Vtec
b18c_ c1, c5 are the gsr and type r, then b18c3
Old Feb 20, 2006 | 10:51 AM
DJYoshaBYD's Avatar
DONT FOR GET THE ALMIGHTY B17A1.... 90-93 gsr 1.7 liter 170 hp..... those heads flow VERY well, but they are VERY hard to come by
Old Feb 20, 2006 | 12:36 PM
Marty's Avatar
The B17 head is no different than the obd1 and obd2 B16 head
Old Feb 20, 2006 | 01:55 PM
Kappa22's Avatar
Yeah, and you forgot to mention the B16.
Old Feb 20, 2006 | 01:58 PM
DJYoshaBYD's Avatar
yes it is.. the ports are different and so are the cams....
Old Feb 20, 2006 | 03:44 PM
jwsimons's Avatar
but why would you want a b16 head on a b18 block? i understand they are both basically the same block, is there anything to be gained by using a 16 head? i did not think there would be, so i kept it to the 18's....
Old Feb 20, 2006 | 03:59 PM
AgentofDarkness's Avatar
If you get a B16 head, it will lower the compression. This would be good if you plan to run a forced induction set up.
Old Feb 20, 2006 | 07:26 PM
antrmo's Avatar
u asked if there was much troble.. well a little ,non vtek to a v-yek takes new wiring on the ecu part and a new oil line to the head aswell..,,,
Old Feb 21, 2006 | 03:04 PM
Nail I3unny's Avatar
ORIGINAL: AgentofDarkness
not from a B17 head. but yeah from most B heads it will
use a SiR head. lower compression and best flowing.
